wiring diagram
Old May 13, 2011 | 06:06 PM
98monty's Avatar
Default wiring diagram
anyone know where i can get a wiring diagram for a 2000 impala with a 3.4L? i put a new compresser in cause the a/c didnt work and the was metal shavings by the clutch and making nosie. the clutch will not engage at all. i tried to jump the low side switch and still nothing. all the relays and fuses are good. is it a possability that the controls inside are not working? i could use any input on this. and i do have 12 volts at the compresser. the only other thing is im not sure if i jumped the low side switch right cause it is a 3 wire, i know that the black is ground but i dont know what one is power, i tried both of them as power and sitll nothing. or do i have to jump it and the have another wire stright to a ground?
thank you to who can ever help me. i've got smoke cmoing out of my ears i've been thinking to long
afterburn
Feb 8, 2008 08:01 PM
PuppetMaster
May 26, 2007 01:25 PM
SleepyEG
Dec 26, 2006 01:03 AM
moxion234
Mar 20, 2005 11:49 AM
