wipers not working
Old Jan 30, 2015 | 02:02 AM
ejj's Avatar
ejj
Default wipers not working
Please help!! I have a 95 monte z34. Recently, my wipers just quit working and I replaced the motor. Nothing still. I used a voltage tester to check the wiper fuse in the passenger side fuse box and there's no power going to it. If that's not enough, my blower just stopped blowing out of the dashboard vents, but still works on the windshield. I have no idea what to try next. Any help would be much appreciated.
Old Jan 30, 2015 | 07:24 AM
Welcome to the forum...
Were here to help.
The heater issue maybe a blend door actuator has failed...
Theres videos on you tube on how to replace it.
Have you also checked the fuses under the hood for the heater/wiper?
You may also need to replace the turn signal/wiper control.
Old Jan 30, 2015 | 09:25 AM
ejj's Avatar
ejj
I did check the fuse under the hood, and it's getting power. Fuse looks OK too. My turn signals and high beams are still working. Could it still be a bad multi-function switch?
Old Jan 30, 2015 | 02:59 PM
Yes I forgot to mention a multifunction switch.
Old Jan 31, 2015 | 02:23 PM
ejj's Avatar
ejj
Thanks. I'll check. Could the switch be bad even if everything else on it (turn signal, cruise control, high beams) works? I'm stumped. Plus if I'm getting no power to that fuse inside, should I check elsewhere or not? Hope I'm asking the right questions...
Pitbullsrok
Aug 11, 2015 10:41 AM
NovaSS369
Apr 17, 2011 11:34 PM
churritos626
Nov 20, 2010 01:25 PM
cornerview
Sep 17, 2010 02:49 AM
jasonmcr
Dec 16, 2007 06:39 PM
