Windshield washer fluid low
Old May 22, 2014 | 08:58 AM
reveal's Avatar
Default Windshield washer fluid low
I have an 07 Monte Carlo LS, and I have filled the Windshield fluid, yet everytime I start my car the little "Windshield Washer Fluid Low" warning comes on yet it's filled. Is there a level or something that senses when it's low and how do I get to it to make sure it's fine.
Old May 22, 2014 | 09:23 AM
There's a sensor in the water bottle. Looks like this:
Make sure the sensor isn't gummed up with something, or the plug is not loose on it.
Old May 22, 2014 | 09:28 AM
reveal's Avatar
Thank you very much, always wondered if there was a sensor and where it would be.
Old May 24, 2014 | 11:26 AM
reveal's Avatar
Dumb question, Is there any easy way to get to it, or do I need to unbolt and take the container out to get to the part I need to inspect.
Old May 25, 2014 | 09:17 AM
Not too sure, you might be able to remove the inner liner of the fender to access it through the wheel well, but I don't know how it sits on your car.
Old May 25, 2014 | 12:11 PM
reveal's Avatar
It's sort of an odd shape and and I can follow it down and then look under the car and see it, does it matter if there is some fluid in there, I can take the first bolt off that holds it to the car then I assume I have to take the inner liner off to actually get to it.
nemesis
FWD Tech Guides '95-'07
Jun 8, 2012 12:02 AM
jshladwig
Dec 20, 2010 10:05 AM
bostock
Nov 22, 2010 09:32 AM
Joe Bloggs
Nov 9, 2009 09:13 PM
SoCalSS
Sep 13, 2006 04:11 AM
