Windsheild defroster problem
Old Dec 24, 2011 | 09:40 AM
03SSLE's Avatar
I do the opposite - I flip on the defroster right after starting my car, and the cold air defrosts my windows within a couple of minutes. Then I flip it over to the vents/floor to heat the passenger compartment.
Old Dec 24, 2011 | 01:12 PM
kingreyna's Avatar
Just a quick update on heater core: I'm about to quit while I'm ahead. It's a freaking hassle to remove the plastic steak screws. I'm just going to try a radiator stop leak which did help my friends 95 monte core leak (he told after I bought the core) or just bypass and tackle it later next year when its warmer or get some quotes on how much.
Old Dec 24, 2011 | 01:53 PM
Justin Knight's Avatar
My heater core is not leaking for sure and days like we've had lately my windshield will fog right away and clears in 5 minutes. Your coolant smell would be the concern for me. The fresh air duct draws from the wiper cowel and you may have an engine compartment coolant leak and that's where the smell can come from. I've also seen washer fluid that smells a lot like coolant and when you spray your windshield it all runs down into that vent area and onto the cabin filter if it has one. If you don't get the coolant smell when it's on recirculate I would rule out the heater core altogether.
Old Dec 24, 2011 | 01:55 PM
And don't use stop leak it will cause a bigger headache than you want to try and fix. After you do change the core (if you need to) the stop leak will clog up the new one and won't be any good after.
Old Dec 25, 2011 | 09:18 PM
04chevyboy's Avatar
I sould live in the north pole,i drive with windows down all year unless its raining or snowing.Just want to defrost my window
owens91
Jun 22, 2015 05:36 PM
tloughrin
Dec 22, 2013 08:47 AM
04chevyboy
Nov 10, 2011 07:39 PM
k_johnston18
May 11, 2011 10:25 PM
alesiter
Apr 4, 2007 06:14 PM
