Windsheild defroster problem
Old Dec 7, 2011 | 06:24 PM
04chevyboy's Avatar
Default Windsheild defroster problem
Okay guys,soo my montes been throwing me problems,just little expensive ones:/ But anyways,ever time i jump in the heat up the car and turn the defroster on for the windsheild it completly fogs the inside up when it wasnt fogged up before,and takes a bout 10 minutes to clean off on full blast heat,what could be wrong?
Old Dec 7, 2011 | 06:28 PM
kingreyna's Avatar
I just had the same problem today but only the driver side and its freaking hard to see. Help!
Old Dec 7, 2011 | 06:35 PM
04chevyboy's Avatar
Its a pain! Cant wait to sell my quad to be able to fix my gauge problem,windsheild wiper motor,and got somethin wrong with my front cig liter which i was using for my gps aka my speedometer! lol
Old Dec 8, 2011 | 07:47 PM
kingreyna's Avatar
I just found out with Google that its the heater core that is bad. The inside smells like coolant and vapor comes out the vents and all my windows are fogged up including my rear-view mirror. One of my friends have my old Monte Haynes manual but I'm hopping its the same for an 02' and an 06' to replace.
Any one know how hard it is to replace?
Old Dec 8, 2011 | 09:41 PM
blackbeauty89's Avatar
haven't done one before, but if i recall it's a pretty intense job. you have to pretty much rip your whole dash apart to get to it. i can't find the proper information on how to replace it, but i know it's a pain.
Old Dec 12, 2011 | 09:11 AM
Shandley's Avatar
It sounds like 2 different issues to me. I mean, they could be the same but I have some moist air come out of my heater onto my windows most days since it was new, especially after a rain or snow or after I wash the car.
Kingreyna sounds like a heater core with the smell of coolant.
04Chevyboy sounds like normal stock issues. I read about a fix on it before to do with the air cabin filter but I never bothered.
10min to clear the windows is extensive but not by too much and it is very circumstantial (ie: weather, air temp, humidity, etc). Do you get the smell of coolant?
Old Dec 12, 2011 | 09:49 AM
Does your air conditioner work correctly? The Compressor helps dehumidify the air when it it set to defrost.
Old Dec 24, 2011 | 12:20 AM
04chevyboy's Avatar
no, no smells what so ever
Yeah,ac works great,heat takes forever tho sometimes. pick up someinside window defogger,maybe it will help but noy to worried about this problem anymore lol
Old Dec 24, 2011 | 07:01 AM
03SSLE's Avatar
I agree that for Kingreyna it sounds like a bad heater core due to the smell of coolant.
04Chevyboy - Try turning down the heat. The difference between the outside ambient temp and the temp of the warm air coming from the defroster will fog the windows. The windows will defog much faster using cool air. Once they are defrosted then turn up the heat.
Old Dec 24, 2011 | 09:32 AM
04chevyboy's Avatar
Ill try that! What ive been doing is turning heat on the floor first then going up to the windsheild,its been working too:p
