Window Regulator replacement
Old Apr 22, 2017 | 01:41 PM
Dolores Evans Appleton's Avatar
Default Window Regulator replacement
I have replaced my driver's side window regulator 2 times with brand new parts. Both of them are out of adjustment some how. The window is tilted and will not go up. Is there anyway this can be adjusted?
Old Apr 22, 2017 | 03:58 PM
First of all...welcome to the forum!
As far as your window being tilted and not going up, are your moving parts that are in the window track all in good shape and not bent? Are areas that come in contact with each other lubricated?
Old Apr 23, 2017 | 08:15 AM
Smile
Welcome to the forum!!
I had a Pontiac Van with the same issue and it is in the Track.
I have included a link to youtube for this repair you may wish to review.
Hope this helps
