6th Gen ('00-'05): When shield wipers not working
Old Jun 2, 2017 | 05:34 PM
owens91's Avatar
Default When shield wipers not working
Good afternoon forum members it's been a while since I've been on here everything has been running smooth up until now I have a question that kind of has me stumped first do anyone know where is the windshield wiper fuse at secondly my windshield wipers are not working I just installed another multi function switch but the windshield wipers still aren't working no fluid is coming out either I was hoping someone can help or point me in the right direction thank you in advance
Old Jun 4, 2017 | 07:12 AM
Smile
Check the fuse panel either the one on the inside of the Car or there is probably another under the Hood. You might youtube it to see if there is a fix there.
Most likely when you installed the switch it may have blown a fuse.
Also check your wiring at the Motor to make sure it has not corroded.
If you have a electrical tester you can find out what is live and what is not sometimes the parts stores will lend this item to you.
This stuff is fairly common between years.
Good luck
