Wheel hub replacement with pics
Old Jan 24, 2016 | 08:41 PM
xpage's Avatar
Default Wheel hub replacement with pics
I'd like to thank everybody here for help and advice as it very useful. I did this back in August so my bolt sizes may be off.
Symptoms:
About a year ago I started getting traction control popping up randomly along with ABS about 6 months after that, it's not so fun when turning onto a busy road to lose traction for a second. Eventually I started getting the security message popping up either mid-ride or when the car started. I thought it was the ignition cylinder needing to be replaced or overridden via a resistor.
Turns out that the security message went away with the wheel hub replacement for the bad sensor on it.
HOW TO STEP BY STEP:
ChibiBlackSheep made an excellent write up ----> https://montecarloforum.com/forum/fw...ssembly-33657/
I hope to add to this with pictures.
FYI I have no impact tools so the hardest part was getting the axle-nut off. Really cranked on it, no luck even with a breaker bar. The breaker bar was bending quite a bit, even my large roommate couldn't crack it. So be sure to have PB blaster and use it, I went to the store then came back and started again. Also get a long piece of pipe to extend the breaker bar leverage. I think this one was ~$10 at home depot.
Remember to use a 36mm socket. You can get a loaner at most autoparts stores, that's what I did. I also loaned a axle puller just in case. Didn't need it
Once the wheel is off an axle nut cracked loose, remove the caliper. 2 bolts (15mm), maybe grind yours down and put caliper paint on them like I did years ago. A small pipe adds leverage and makes life easier.
Hang it via a bungie cord, makes life easy.
2 more bolts to do (13mm) these are a different size than the previous.
Remove the rotor, I used these locks (optional) to help keep the jiggle down after my brake and rotor replacement years ago. Had to bend the teeth to remove them, replaced with new ones (optional)
Finishing removing axle nut (note i didn't remove my rotor yet in this pic)
The hub has 3 bolts to remove, two on the bottom one on the top like a triangle. For me the hardest is the top. It really pays to have a ratchet that has an adjustable head angle, and I needed an extension to get the top bolt off easily without my ratchet getting in the way. A ratcheting wrench can solve this issue too.
The bottom left bolt is shown here
Me using the extension to get the top bolt off.
DISCONNECT THE SENSOR before you attempt to remove the wheel hub, unclip the sensor, and hope the hub will pulls off easily, else use the hub puller.
Another angle. Remember the orientation of the bracket. Your sensor will clip into this bracket.
Here's your old wheel hub
Your wheel hub hole is probably grimey so clean the inside of your hub hole and then insert the hub. Have the sensor wire in the same position, remember the new sensor has a clip too. Getting the bolts back in can be a pain too, I started the the top one first then added the others. The wheel hub will slide into the CV axle as you tighten the axle nut, so don't worry if it isn't in all the way. Relatively painless job, assuming you have the right tools.
Old Jan 24, 2016 | 09:03 PM
Thanks for the write up with pics!! Good job!!
Old Jan 25, 2016 | 03:35 PM
Glad my write-up helped you
Although a note to everyone, it seems like GM liked to change axle nut sizes constantly. Hopefully you have a way to test before you purchase, or pick up a few sizes and return what you didn't use.
Old Jan 25, 2016 | 07:55 PM
owens91's Avatar
sometimes when you get the axle nut kit they just come with an assortment of different sizes
