what would you do
what would you do
I am having some trouble with my 95' Monte. The rear bumper has quite a substansial amount of rust on it. I was looking online and found www.rust911.com has anyone ever used this stuff and do you think it would be safe to use? I found a couple other products like evap rust but the rust911 seems like the more economical purchase. Thank you for your input.
on the 5th gen? its as plastic as can be.... maybe something underneath is metal i havent crawled around. But the bumper is plastic for sure
Sounds like an impact bar or inside the trunk is rusting.
If it's truly rust, clean the debris off (a wire wheel works well) and I've been happy with POR15.
I'm pretty sure all 5th gen bumpers are plastic...anyway idk the name of the product but napa sells a product that kills rust turns it black makes it fall off and then you cand o what youd like to fix it. I'm going to get some for the rust on the inside of my truck doors then sand it down and put some roll on bedliner on it.
