What should normal coolant temp be
Old Apr 4, 2007 | 05:00 AM
TrapShooter8's Avatar
Default What should normal coolant temp be
What should the normal coolant temp be running on a 05 Monte with the 3.4 V6?
mine is running at about 200 right in the middle of the gauge, is that the normal range?
Thanks, Mike.
Old Apr 4, 2007 | 09:35 AM
bilms01's Avatar
Default RE: What should normal coolant temp be
My 00 LS 3.4 and my 06SS 5.3 run normal about there middle on the guage. That sounds about right with the 195 T stat.
Old Apr 4, 2007 | 10:28 AM
wiz kidd's Avatar
yah your fine, the t-stat should be a 195 in there...and most cars i've driven unless they have a 180 in them sit around the middle of the guage
Old Apr 4, 2007 | 01:49 PM
Thanks,
I thought it was normal, but on most of the recent vehicles I have owned the temp gauge stays alot closer to the low end of the gauge, not in the middle.
Mike.
Old Apr 4, 2007 | 02:45 PM
GrandPaDave's Avatar
ORIGINAL: TrapShooter8
Thanks,
Mike.
I used to build meters and guages and I can confidently say that the poor quality of meter installed on today's cars is probably hovering around a 5% margin of error.
I wouldn't be surprised if it was even 7-10% error.
Old Apr 4, 2007 | 10:24 PM
04 Intimidator's Avatar
I wouldn't worry about it then... Once it hits 210-220, then swap the T-Stat. If that doesn't do it, start worrying.
ecosta221
Aug 21, 2020 10:35 AM
michelob
Jun 28, 2015 10:25 AM
mrjaysc
Oct 10, 2013 11:17 AM
ecosta221
Jul 5, 2013 10:44 AM
Leprechaun93
Aug 17, 2011 12:06 AM
