what piece for door lock :1997
Old Aug 30, 2009 | 03:28 PM
christophe mc france's Avatar
Default what piece for door lock :1997
hello all people / for a modele 1997 5th generation (the best car in France)
when i m in the car
and when i touch for the button Lock ; there s only the right door locked.
WHAT IS THE PIECE I MUST CHANGE ?
I can buy it on the rockauto catalog
christophe
Old Aug 30, 2009 | 07:39 PM
skylark65's Avatar
it sounds like if it wasint the fuse you should remove the trim peice around the door handle & lock and check to make sure the electrical plug into the lock swich has currant leading to it, or if its corroded / loose. start as simple as you can with this, the modual is somwhere behind the dashbord according to my haynes repair manuel.
also, does the power lock swich on the left door function properly? does it lock the right side door, both doors, or neither?
DerrtyD
Apr 26, 2013 11:49 AM
Sep 15, 2009 04:40 PM
Aug 30, 2009 08:04 AM
jeffrae
Dec 21, 2007 04:30 PM
Nortybignort
Jul 27, 2006 11:32 PM
