6th Gen ('00-'05): Weird problem with turn signals + high beam
Old Dec 9, 2018 | 11:00 AM
mrzombiefingers's Avatar
Default Weird problem with turn signals + high beam
Attached is a video showing the problem I am having, in the video it shows the high beam out light coming on but I forgot to mention that the actual high beam and low beam is still working on the outside.
Also the vehicle has been scanned for codes and nothing showed up.
https://www.youtube.com/watch?v=XDcTfozE-cU&feature=youtu.be
Thankyou for any input on this
Old Jan 23, 2019 | 08:36 PM
Molly Rose Callahan's Avatar
https://www.youtube.com/watch?v=XDcT...ature=youtu.be
I don’t have any input, but I did want to let you know my 2000 has been doing the same thing. I replaced the turn signal lights this morning and it stopped fast blinking for a second, then went right back to it when I left work. It looks like one of my fog lights is also out, I’m going to see if replacing it helps and I’ll let ya know.
Old Jan 23, 2019 | 11:42 PM
Well if I had to guess you have probably got just some poor ground somewhere or dirty wires to the area. However there is also a relay that could be going bad and that maybe something to check into. Relays are usually under the hood in the fuse box. I don't think you can test them. But you can locate it and replace that item. I would check all the grounds first clean the contacts and if that doesn't work change the relay. Connections are very important when you check this out. Make sure they are tight and clean.
Sometimes if you get a cheap bulb it will make the signal lights go crazy too. I got some once at the box store and worked for about a week and went out and then I went to NAPA and haven't replaced the bulbs since. good luck.
Monte Carlo Lover
Nov 20, 2024 07:41 PM
jimack
Jun 22, 2022 09:22 AM
Zod642
41
Jan 27, 2018 09:56 PM
westcoastmc
Mar 27, 2017 05:51 PM
Steven21
Mar 23, 2014 08:33 AM
