weak headlight
Old May 2, 2010 | 07:44 PM
ho350's Avatar
Default weak headlight
I've got a weak drivers side low beam (new bulb)on ny 1985 Monte. A friend suggested it may be a relay. I have little knowledge of things electrical. Does a relay sound plausable? Where would I find the headlight relay?
Old May 2, 2010 | 07:51 PM
mak330's Avatar
how old are the bulbs. sounds to me like one is reaching the end of its life. try to switch the bulbs and see if the problem persists.
Old May 3, 2010 | 11:27 PM
Sliver's Avatar
I agree with mak330, switch the bulbs from one side to the other. Also check the connection for corrosion.
Old May 4, 2010 | 01:25 PM
ho350's Avatar
I've actually got new bulbs on both sides. I'll swap them when I can get out to the garage and give that a try. Maybe it's a bad bulb.
marcros
Apr 7, 2015 06:48 AM
tps221
Nov 27, 2013 04:34 PM
zzapultimate
33
Dec 17, 2008 01:44 AM
Magna131
Oct 27, 2005 04:36 AM
