Water pump replacement ?
Old Apr 13, 2010 | 10:05 AM
Rich's Avatar
Default Water pump replacement ?
Does anyone have instructions on replacing the water pump on an 02 Monte SS. 3.8 ENGINE.
Thanks.
Old Apr 13, 2010 | 11:36 AM
For the L36 disconnect battery, you drain the coolant, remove the accessory belt / water pump pulley bolts. Pull off the water pump and clean the gasket area.
Then reverse with a new gasket put on the water pump and tighten down the bolts, put the pulleys back on and refill coolant system.
Fubba
Apr 10, 2011 08:39 AM
pilotknob1964
Oct 3, 2009 01:53 PM
Monte SSV
Sep 9, 2009 11:18 AM
sportjunkee
Jan 13, 2008 07:13 PM
Brooke
Oct 17, 2007 04:35 PM
