Water pump replacement ?
For the L36 disconnect battery, you drain the coolant, remove the accessory belt / water pump pulley bolts. Pull off the water pump and clean the gasket area.
Then reverse with a new gasket put on the water pump and tighten down the bolts, put the pulleys back on and refill coolant system.
pilotknob1964
Oct 3, 2009 01:53 PM
sportjunkee
Jan 13, 2008 07:13 PM
