Water leak somewhere
Old May 15, 2007 | 10:36 AM
dthoren's Avatar
Default Water leak somewhere
Ok my airbag light came on the other day and i took it to a shop to have it fixed the guy scanned it and told me that the module was bad when they went to replace it they found out that it shorted out because the rain water is leaking into the passenger side of my car they said they found the leak to be the weatherstripping around the cabin air filter was bad. It rained last night so this morning i went out and checked and my floor is wet any other ideas as to where it could be coming in.
Old May 15, 2007 | 11:15 AM
ozzy_osborn's Avatar
Default RE: Water leak somewhere
i replaced an airfiler on a car or mine for the freshair there by the windshiled...and i broke a little piece off and come to find out that piece let a bunch of water get into the car....
Old May 15, 2007 | 04:18 PM
04 Intimidator's Avatar
Easy way to find out is hit it with a garden hose and wait till water starts coming in. Then just trace it.
Old May 15, 2007 | 05:49 PM
dthoren's Avatar
ok found out where its coming in it pools in the cornor of the filter and then after geting over saturated it drips into the car
so my fix was to drill a small hole there to let the water out tested it with a bucket no watter comes in
Old May 15, 2007 | 08:33 PM
wiz kidd's Avatar
very good to hear
Old May 15, 2007 | 09:23 PM
Did the garden hose help out or did you use another idea to help find the water leak?
Old Jan 17, 2014 | 11:54 PM
Bellyisis's Avatar
It can get water there for 2different ways too. Does your monte have a sunroof? If it does have the drains checked.. They can get clogged from dirt and leaves. Or the cowl that sits on windshield after time the clips break so seal fails letting water in.
VictoryRedSled
Jun 14, 2013 08:53 AM
rgant_19
Mar 6, 2010 12:33 AM
red04montels
Dec 30, 2009 12:31 AM
One Dark SS
Feb 18, 2009 05:04 PM
Brooke
Oct 17, 2007 04:35 PM
