Vibrating steering while driving
I've got this weird vibration while driving. I can feel it in the steering but also throughout the car. I've replaced the wheel hubs, new brake rotors and new tires, all which were necessary fixes anyway, but the problem is still there. I'm wondering if the alignment is bad? I've already spent enough on this car this month and don't want to shell out $70 more if I can avoid it, and if that is the issue I'd like to know. Just getting sick of it. It definitely feels like it's coming from the wheels I doubt it's engine related at all. I don't drive particularly rough roads etc. thoughts?
You have a bent rim? The wheels and tires are improperly balanced? Maybe it threw a wheel weight? Have you had the balance checked?
How many miles on the "New" tires? Or are they used tires that are new to you? Maybe the tires are out of round? If its out of alignment generally it will pull in one direction or the other... Does it pull? Did you hit a curb? a bad pothole?
Maybe you have broken motor/trans mounts?
go under car grab axle by different segments and wiggle.... should be very little play. Although with this issue my symptoms were more prominent when trying to accelerate.
like above said, tighen and check condition of motor and transmission mounts, also check upper mounts, the rubber sleves are very easily to damage.
try to tighten down any loose bolts, check entite suspension.
if not that, jack both wheels up and have someone to spin the wheels up, you should be able to isolate the vibration from there.
Thanks for the replies. It does not pull at all in a direction. It vibrates at random while driving, sometimes worse than others but not worse while accelerating. The faster I'm going it seems to be worse. The tires are brand new. I know what you guys are saying about trans and engine mounts but I just really don't think that's it.
Raise your car on a Jack like you are changing a flat but don't take wheel off. Then reach under and grab your axle. As said above, there should be little if any play.
My inner CV joint was bad and it gave me those same symptoms.
Thanks-I will check the axle. If that IS it...how hard is the axle to replace? I just replaced the wheel hubs last weekend (thinking that might be the problem, they were bad too) and it seemed like it wouldn't be too much more to take off to get the axle off.
Reason I think that might be it, is the mechanic mentioned about 6 months ago that it might need to be replaced but that it's no big deal. From the way he said it, it sounded like he was just trying to make some cash off of me, but now...it's got me thinking for sure. I've been chasing this vibration for a while, and several hundred dollars later, I'm ready to be done with it.
