Vibrating steering wheel and front wheel squeaking.
Old Jun 7, 2017 | 05:01 AM
silkwormxl's Avatar
Default Vibrating steering wheel and front wheel squeaking.
Hello everyone,
I have a 2006 Monte Carlo LT with 120k miles on it. Two days ago I noticed when I first put my car in reverse (or drive) to leave my driveway, I hear a metal squeaking sound coming from the front wheels. Then, while driving, it feels like the road is bumpy and the steering wheel slightly vibrates until I reach 60+ mph. I don't notice any squeaking when I break - it's only when I'm first pulling off under 5 mph.
I've checked around on these forums for similar postings, and it sounds like it could be a wheel hub / bearings issue. That sound about right?
Thanks!
Old Jun 7, 2017 | 07:25 PM
96z34man's Avatar
It's definitely related to something that turns, and has metal in it. That narrows it down to the hub, the rotor, or the tire. It ain't the tire. No squeaking when you brake doesn't mean it isn't the brakes--the modern wear sensor squeaks when you don't brake, not when you do.
So, brakes or hubs.
Old Jun 7, 2017 | 10:19 PM
I agree, modern wear indicators can squeak sometimes when you don't brake and stop when you do brake. I would first check the health of your rotors and pads. As for the vibration, not sure the best point to start other then jack the car up and wiggle test all the suspension parts. I had cheap/crappy rotors on a car from the previous owner and the back side of the rotors was coming apart, caused a variety of problems, including a balancing issue (had a vibration like a wheel was out of balance, here it was a crap rotor).
Old Jun 12, 2017 | 02:11 PM
silkwormxl's Avatar
Problem Solved: Took it in to the mechanic this morning. Ended up being separated tread on the front driver-side tire. Apparently from hitting something like a pothole. Wasn't me - most likely the girlfriend who also uses the car. In any event, got both of the front tires replaced. They said the metal squeak sound was from rust build up on the breaks due to the Oklahoma humidity. Haven't heard any more squeals and my car is steady once again. Good as new!
Thanks all for the input!
Old Jun 13, 2017 | 04:38 PM
96z34man's Avatar
Even though I said it wasn't the tire, I did offer that as one of the three possibilities. So...(bowing deeply) Glad it's solved.
