Unkown vacuum line
Old Oct 24, 2017 | 02:17 AM
Dboybakr's Avatar
Default Unkown vacuum line
2001 Monte Carlo 3400. Can any body tell me what this vacuum line is for? Theres a vacuum nipple on the back passenger side of intake manifold. Right by the alternator and power steering pump. Ive attached a pic and circled what im talking about, but its not a pic of my actual motor. Its a pic off google. Almost identicle to my motor except the vacuum nipple on my motor has a hose attached to it aprox 1/8" diameter. The hose goes down behind the alternator toward firewall and i cant tell where it goes from there. Does anybody know what it is for?
The reason i ask is because the rubber elbow connecting the hose to the manifold is constantly tearing and causing a vacuum leak and the engine to sputter real bad. Im thinking whatever is on the other end of the hose might need to be cleaned or replaced. Its a very skinny hose and i dont want to take a bunch of stuff apart just to follow it. So im hoping somebody can tell me where it leads to.
Thanks in advanced
File Type: jpg
Old Oct 24, 2017 | 08:37 AM
Smile https://www.youtube.com/watch?v=-9E62lMkwRs
Here is a youtube vid I found that may help.
Old Oct 24, 2017 | 09:58 AM
plumbob's Avatar
Pretty sure you're talking about the HVAC vacuum line. Is the HVAC blower air pressure weak?
Below is a link to a old thread I commented on with description, routing and pictures. The car is a '00 SS with 3.8L but the vacuum harness is probably the same except for the intake manifold connection. The line passes through the firewall and connects to HVAC controls.
https://montecarloforum.com/forum/mo...k-tower-57414/
