Turn Signals and Hazard Lights Don't Work
Hey guys, I have a problem. Yesterday my turn signals and hazard lights stopped functioning. Every other function with the signal switch works. i.e. the highbeams and the windshield wipers. . .What is causing these to stop working? I have checked the fuses and all of them are good. The switch itself is good. . .so I'm kinda at a dead end.
Thanks for any help.
Brian
Brian
RE: Turn Signals and Hazard Lights Don't Work
Pretty sure its the module on the far left where the button is. Its harness comes out of the back with yellow, green, black, and blue wires.. This was on an 06, so Id assume the 00-05 are similar. This is a pic of the top cover of the column removed.
Yeah and of course you will not notice until the dashboard is fully re-assembled. Lol. And will only realise it after an hour of scratching your head and cursing.
ORIGINAL: HyperFox
I know malibus were notorious for having them go out.
Mine bit the dust twice. The relay was located behind the hazzard button in the G.A. also. It was too much of a pain in the butt to change myself, so I had the dealership change it for me.
ORIGINAL: HyperFox
ORIGINAL: monteriderLS
No I haven't had the dash apart ever. It just went out yesterday when I went to use the turn signals. . .I'll take out the dash and see what I can figure out.
