trying to pass
Old Aug 10, 2017 | 02:02 PM
avendo's Avatar
Default trying to pass
lately I have been had a problem trying to pass another car,car just bogs and a few sec later it goes..i could be in 2nd or 3rd..so annyoning,got new plugs ,wires,air cleaner is clean..any ideas?
Old Aug 10, 2017 | 02:11 PM
Torque Converter could be locking up and not releasing properly. Are you manually in 2/3 on the shifter at the time? Or do you just know in overdrive what gear you are in?
Could be a clogging catalytic.
Those are common culprits on these cars.
Old Aug 10, 2017 | 06:11 PM
Question
X 2 when is the last time you changed the fuel filter? The Cat converter is something to check
Old Aug 10, 2017 | 11:07 PM
X3with the potential clogging catalytic converter. Not throwing a code yet, but effecting your performance. Is your fuel consumption getting to be more than your old average?
Old Aug 11, 2017 | 05:13 AM
avendo's Avatar
I have a new cat..im getting about 22mpg between highway and regular roads..fuel filter I have to address cause its rusted on.might need a dorman kit..i am usually in 3rd on back roads..i just cleaned the MAF last night..will test today.
