Transmission question
Old Apr 6, 2008 | 09:17 AM
DEI Monte SS 04's Avatar
Default RE: Transmission question
Auto Zone techs do not have the right reader to see if it is working properly. You need to take it to a tech. with something like a Sun Gauge not just a code reader. It has a graph to analyze the code or monitors in the computer system. Chevy or any good repair shop should be able to do it for you.
Old Apr 6, 2008 | 09:30 AM
TUMTUM83's Avatar
thanks
Old Apr 8, 2008 | 07:27 PM
RocknSS04's Avatar
A bad cat' WILL NOT throw a CEL code. You will have a loss of power and bad tranny shifting. As far as I know, the only way to check one is to drill a small hole before and after the cat to check the diff' in backpressure. You have a 10 year/100,000 factory warranty on the emissions system.
I just threw a P0455 code ( I think that's it) evap' sys' major leak, and I checked my gas cap. It was NASTY around the seal area. Wiped it clean on both sealing surfaces, and haven't threw a code since.
Old Apr 8, 2008 | 07:43 PM
TUMTUM83's Avatar
thanks..i have a appointment with them 2morrow...should i print out something...will they charge me for the diagnotics?
Old Apr 8, 2008 | 09:49 PM
Cloud_Master's Avatar
What is this line pressure you are referring to?
ORIGINAL: mtwallet
Nice work guys!That's exactly what it was. 3 PSI at 2000 rpm. Anyidea what it should be?
Old Apr 29, 2008 | 10:27 PM
mtwallet's Avatar
Sorry for the delay CM. I haven't been on the site for a while. The 3 PSI was the pressure measured from the exhaust. My cat was plugged up.
JuniorCar
22
Nov 3, 2014 11:51 PM
2003supersport
Feb 28, 2009 03:00 AM
freeguy555
May 23, 2008 07:32 PM
bRitch022
Apr 2, 2008 06:29 AM
Aaron_Provost
Dec 12, 2007 08:17 AM
