Transmission Hot / Idle Engine
Old Oct 31, 2013 | 08:12 AM
Daymack's Avatar
Default Transmission Hot / Idle Engine
I got this message on the drivers information center on my 2007 Monte Carlo SS several different times. It happens mostly when driving on the highway.
The dealership has looked at it but no codes are registered and they checked the tranmission fluid temperature and the sensor and all checked out okay. They were not able to recreate the message when test driving.
Has anyone out there had this problem and what was the final resolution?
Thanks.
Old Oct 31, 2013 | 08:27 AM
Hiroska's Avatar
Does it shift hard? Hows the temp needle on your guage? Sounds like your tranny may be going out. Did the check engine light ever come on?
Old Oct 31, 2013 | 10:01 AM
Daymack's Avatar
It shifts normal. Temp guage is where it should be. No check engine light.
No unusual sounds coming from the tranny. Trans fluid is pink and doesn't appear to be getting burned up.
"Tranmission Hot / Idle Engine" comes up on the driver info center and goes off right away. It never stayed on for any extended period of time.
Old Oct 31, 2013 | 10:03 AM
Hiroska's Avatar
Any added mods? tunes or anything? Or completely stock?
Old Oct 31, 2013 | 10:27 AM
Daymack's Avatar
Stock.
Trans. fluid and filter changed about 3,000 miles ago.
Old Oct 31, 2013 | 12:30 PM
Hiroska's Avatar
Did the problem exist before then?
Old Oct 31, 2013 | 01:54 PM
Daymack's Avatar
No problems until last week.
I had to drive from Dayton, Ohio to Columbus, Ohio a couple of times last week (around 70 miles each way and mostly highway miles) and the message came up 4 times on the first trip to Columbus but no messages on the way back. Just the opposite the next day, no messages on the way up but the message came up 5 times on the way back.
I let it sit until I had a chance to let the dealership look at it. Got the car back last night and drove it to work today with no problems.
Very confusing.
Old Oct 31, 2013 | 02:07 PM
JC Colon's Avatar
When you did the Trans Fluid and Filter did you drain it or Flush it? You may have a Clog in the Trans Cooler or one of the lines!
Old Nov 22, 2013 | 04:16 PM
Daymack's Avatar
I wanted to update this thread for anyone else who runs into the problem.
As time went along the "transmission hot/ idle engine" became more frequent, especially when driving on the highway at 65 to 75 mph. The transmission began having problems shifting into overdrive or would not shift into overdrive. This is consistent with other forums (Cadillac and Grand Prix forums) who indicated the same problems.
Therefore, I had the transmission rebuilt and just got my car back today.
Feb 1, 2013 07:35 AM
kingreyna
Jul 23, 2011 11:17 PM
gopack47
Aug 11, 2010 09:46 PM
sacclark
Dec 15, 2007 10:37 AM
24_48Fan
Jan 6, 2007 07:47 PM
