5th Gen ('95-'99): Transmission cooler line replacement
Old Sep 30, 2016 | 03:41 PM
Matthew April's Avatar
Default Transmission cooler line replacement
Hi there, my ('95 Z34) transmission cooler lines are rusted and dripping fluid. Does anyone know how difficult of a job replacing them is? I know it should be fairly simple on most cars, but i don't have a jack handy right now to take a look. Mainly wondering if i will need to dismantle anything major in order to get the job done.
Old Sep 30, 2016 | 09:17 PM
l67ss's Avatar
remove passenger fan and possibly a small clamp/bracket at the bottom and its not bad to change from the top
Old Oct 2, 2016 | 09:07 PM
ok, took a look today and looks simple enough. Do I need to drain the fluid first?
Old Oct 3, 2016 | 10:36 PM
nitehawkjcb's Avatar
I haven't drained the fluid whenever pulling the motor & tranny, which requires those lines to come out of the radiator. You'll lose some fluid, but not 3-6 quarts like dropping the pan.
