6th Gen ('00-'05): Transmission Concern
Old Sep 17, 2019 | 01:04 PM
Rmish77's Avatar
Default Transmission Concern
So I recently was given a 2005 Monte Carlo. A friend of mine owned it and was driving when it lost all power. The engine rev'd by the tranny wouldn't engage. He pulled over and parked it. After I had it towed to my house I tried driving it down the block and back. It drives. Last night i dropped the pan. The fluid is a dark brown/black. Doesn't smell burnt. Once i got the pan off I noticed maybe 5 or 6 metal flakes and a thin cylinder pin mayber the size of a watch band pin stuck to the magnet. Anyone know if its a lost cause?
Old Sep 17, 2019 | 06:05 PM
xpage's Avatar
Not a transmission expert but I'd guess those are probably gear teeth or syncho ring teeth. You'll need transmission fixing. in the meantime if that isn't possible, try replacing fluid, filter, and when adding new fluid add some additive to increase the viscosity to help it grip during shifting.
Old Sep 21, 2019 | 08:50 PM
Just my opinion, but since you've got broken hard parts in the pan, I wouldn't waste time changing fluid. It's too expensive to do on a trans that needs pulled apart.
DiggerDodge
Mar 7, 2012 08:49 PM
86montecarlocl
Mar 17, 2011 09:29 AM
JaxJim
Dec 23, 2010 07:57 AM
rpd709
17
Nov 14, 2010 10:54 PM
ashleymc34
Jan 24, 2010 07:17 PM
