tranny slip
Old Jan 1, 2015 | 08:32 AM
avendo's Avatar
Default tranny slip
I was sitting at a light and when it turned green I went to go and it felt like I was in neutral and then stuck it in gear and then I went,like a 2 sec delay..i have to change fluid and filter,car has 89k on it...think its just fluid?
Old Jan 1, 2015 | 10:08 AM
owens91's Avatar
it could be that u might get away with just changing the fluid but beware these transmissions are a weakpoint so it might also be time for a rebuild just hope for the best, im in the middle of getting mines rebuild as we speak
Old Jan 1, 2015 | 05:08 PM
avendo's Avatar
just got the car,dont want to rebuild tranny,....
Old Jan 1, 2015 | 09:56 PM
owens91's Avatar
worse come to worse that might need to be done
Old Jan 1, 2015 | 11:22 PM
el pachuco's Avatar
My '03 started doing the same thing at 100k miles and a fluid and filter change took care of the problem. DO NOT do a flush. Just a fluid and filter change. And I recommend using the Castrol "high mileage" fluid.
Old Jan 2, 2015 | 07:00 AM
avendo's Avatar
Is that dexron 6 for gm?
Old Jan 2, 2015 | 08:55 AM
blackss01's Avatar
deff dont do a flush change the fluid and filter you can alway use royal purple its expensive but it seems to work good in i very high mile truck that i had
Old Jan 2, 2015 | 09:08 AM
avendo's Avatar
I like to use lucas tranny conditioner also in all my cars
Old Jan 2, 2015 | 09:27 AM
owens91's Avatar
Have u ever used Lucas trans. Slip? That prolonged my transcript very well
Old Jan 2, 2015 | 10:34 AM
el pachuco's Avatar
refer to your owners manual. If it calls for Dexron III and you use Dexron VI, you're not doing it any good at all.
