Tranny Problem??
Old Feb 18, 2013 | 10:51 PM
Harlan2012's Avatar
Default Tranny Problem??
My car shifts good when i first start drivin then when it warms up it shifts into gears slow and drags. Any suggestions?? I have a 2002 monte carlo ss Thanks in advanced
Old Feb 19, 2013 | 07:33 AM
Could also be a clogging catalytic converter, common on these cars and can give the symptoms of a sluggish transmission
Always a good idea to do a pan drop and filter change though
Old Feb 19, 2013 | 09:29 AM
X2
Old Feb 19, 2013 | 12:27 PM
Harlan2012's Avatar
Thats wut i was thinking. Ihad already bought a tranny filter n fluid. Is it hard to change the filter?
Old Feb 19, 2013 | 02:09 PM
If you have the right tools (jack and jackstands and such) it's not a terrible job. Could be a little messy
Old Feb 20, 2013 | 09:59 PM
Harlan2012's Avatar
I got a jack and a jackstand. Where is the filter located? And how would i do a tranny flush
Old Feb 20, 2013 | 10:18 PM
It wont be a flush persay:
After jacking up the car/Supported by the jack stands...
Unbolt the trans pan (becareful to not remove it to quickly)
Remove the filter/replace the filter/ and bolt the trans pan back on. (with a new trans pan gasket)(becareful to not over tighten the bolts) add approximately 7 1/2 quarts of trans fluid and walla your done!
Test drive it.. besure to get it up to operateing temp and recheck your trans fluid level... add more if needed... Otherwise you should be good to go!
Old Feb 20, 2013 | 10:25 PM
Harlan2012's Avatar
Ok what if i wanna use lucas tranny fix? Will i need to flush?
Old Feb 20, 2013 | 10:34 PM
Nope a fluid flush is not possible without pulling the trans...There wil still be residual in the torque converter as well as the radiator...
And that still wont remove all the contaminants... Cause its built up in the lines ,tank and transmission... etc.
The only real way is to hot flush it...Throughly thru the whole system... That has to be done professionally!
If you dont want/do the trans filter and just add the lucas... Wait until the trans is 1 quart low before you add it....
But I highly recommend you do the filter fluid change... and just get 1 less quart of trans fluid and add the Lucas in its place...
Old Feb 20, 2013 | 11:02 PM
Harlan2012's Avatar
Ok thanks for your help.
