Tranny fluid/filter change & weird noise
RE: Tranny fluid/filter change & weird noise
ORIGINAL: 2000_BLACK_SS
When i did mine a month ago i had a gasket that i re-used because it was ribbed and it was also metal with a rubber coating on it and the directions said that came with the new filter said to re-use the gasket if it was like the one i had.
Do you remember what torque spec you used on the pan bolts?
dcnaser
03-25-2012 07:40 PM
tridski
03-01-2010 03:48 AM
slinkeey
02-03-2009 10:33 AM
