Traction Control (not the typical issue)
Old Apr 18, 2013 | 06:53 AM
mr. roboto's Avatar
Default Traction Control (not the typical issue)
Having a problem with the MC. I was having the typical problems with my traction control system (traction control activating when backing out of parking spaces, service traction light intermittently) so I had the ECU read and it was throwing a code for the front right wheel speed sensor. I replaced that hub bearing this past weekend, and now those issues have stopped, but now after I drive the car for 1-2 miles, the "TRAC OFF" light comes on with no messages being displaced on the screen. If I push the traction control button, nothing happens, I can't get the traction control to turn back on (unless I turn the car off then on again).
This is a new one for me, anybody experienced this one before? Thanks in advance!
Old Apr 18, 2013 | 07:44 AM
03SSLE's Avatar
Have the PCM read again using a scanner (Tech II or equivalent) capable of reading all (powertrain/chassis/body) codes.
Old Apr 18, 2013 | 07:51 AM
Also check the wiring of the hub you just changed
Jul 8, 2012 08:27 AM
mrl390
May 7, 2011 08:26 PM
Endo
Feb 15, 2011 02:14 PM
7498MonteCarlo
Oct 24, 2010 08:58 PM
01montesf
Aug 11, 2009 12:40 PM
