Traction Control/ABS going off...?
Old Dec 18, 2009 | 12:21 PM
02SSKID's Avatar
Default Traction Control/ABS going off...?
Ok I'm new and not really mechinically inclined, but I have been having issues lately with my traction control and ABS turning off, when I turn my wheel all the way to the right or left . Its quite annoying as u might know the light stays on and obviously i don't have those options anymore once it does. I would like to try and fix the problem before the snow really starts to pile up here in MI... If anyone could help me out on this problem it would be most appreciated. Thank You!!!
Old Dec 18, 2009 | 12:30 PM
https://montecarloforum.com/forum/sh...action+control
Take a look. Common problems, could be nothing serious.
Old Dec 18, 2009 | 01:43 PM
seawolf18's Avatar
Check the condition of the battery and alternator. If they are putting out low voltage, it will cause the warning lights to come on.
Old Dec 22, 2009 | 01:15 PM
Joe Bloggs's Avatar
I recently had traction control issues with my 2007 Monte Carlo LT. A very common issue with these cars and also Impalas is that the connection harness at the front wheels get dirty and/or wet over time. This causes the traction control to get a faulty signal. I had mine replaced while the car was under warranty and it fixed the problem. However, I found articles online (including this room) that said these connections can be cleaned and dried. This is common and may solve your problem. The dealer noted my ticket as (water intrusion). When this problem returns, I will clean and dry the connections.
Old Dec 22, 2009 | 02:13 PM
u can also check ur brake fluid level, i had a prob on mine where the trac control would shut off & sometimes my abs light would come on & it turned out to be low brake fluid
Old Dec 22, 2009 | 02:30 PM
Low brake fluid is usually just the BRAKE light in your dash
Old Dec 22, 2009 | 02:39 PM
i had a prob with my trac control shutting off when i took off from a stop & not spinning the tires at all, & after i topped off the fluid it quit shutting off, that's what solved my problem
mwmarshall
May 14, 2022 02:43 AM
Chris s
Jan 27, 2013 04:30 PM
tridski
Jun 26, 2006 09:55 PM
Bob50th
Jan 7, 2006 09:46 AM
