tire pressure code
Old Aug 28, 2005 | 04:33 AM
cj702's Avatar
Default tire pressure code
hey guys i have a "low tire pressure" code that is on constant now. i have check tire pressure everyday for a week straight. it is exactly where it is required to be. i need help
Old Aug 28, 2005 | 06:41 AM
mickey's Avatar
Default RE: tire pressure code
if you have doen anything with your tires like rotat or changed them etc... then reset it on the radio options screen.
If you have done nothign with it check under your car and make sure the sensors are still pluged in or not tore off etc...and are in good shape.
Other wise take it in and let them know what si gong on If under warrenty.
abou al i can tell ay with out actually seeing the car would be try to reset it and try it.
Good luck
Old Aug 28, 2005 | 12:07 PM
montejass's Avatar
Welcome to our forum!!! As Mickey noted, reset your tire pressure monitor. Did you have a low tire at some point causing the sensor to trip?
You can find info at the link below on how to reset your tire pressure monitor..
https://montecarloforum.com/m_4913/tm.htm
Old Aug 28, 2005 | 12:50 PM
04MonteLS's Avatar
yeah, as you noticed, the sensor doesn't reset itself once you fill up the tires, although it would make more sense if it did. Just reset it and you'll be golden!
UmmaGumma
Dec 18, 2017 12:43 PM
joe111599
Jun 10, 2016 07:01 PM
sal23
Jul 9, 2013 05:46 AM
Randy Biron
Jul 14, 2012 08:07 PM
Greeny
Oct 30, 2006 11:50 PM
