Tie Rods/Electrical issues with ABS
Old Jan 20, 2009 | 10:21 PM
Someairforceguy's Avatar
Default Tie Rods/Electrical issues with ABS
So I put my car onto a lift about a month ago(I havent been able to touch it here in minnesota with 30-50 below weather), I moved the wheels left and right as they were free to move, as i did so i kept an eye on the tie rods. The tie rods joint that met the wheel was stationary, but the one under the boot moved. Ive heard of a way to test the tie rods by disco. the end meeting the bearing (wheel) and checking for sloppiness(freeplay etc) I have the tie rods sitting in my trunk, just waiting to be put on. Im getting sick of constantly making adjustments as i drive, i need to get these rods on (by the way when i was moving the wheel i had a hand on the tie rod and felt it shift a little) Also im having issues with my abs..it doesnt work. I figured it was the bearing (altho i regret not checking the resistance on the sensor) Turned out after i put on the new bearing it wasnt the bearing, i did test it was a OB2 reader with the ABS option(cost about 280), said the Driver front wheel spd sensor was disco/shorted..So i replaced the bearing and no go, going to try wires next, have the new wire, however i have to splice it (the new wire connects to the bearing speed sensor) and hope it works, I havent tried disco'ing the battery, but wouldnt the system reset after driving for 45 minutes? I thought it did a cycle as u drive to make sure everything is running the way it should.
Duncan
cprince
Aug 13, 2015 10:53 PM
BrandonStebing
May 18, 2015 11:18 AM
04intimidatorssjmm
Sep 27, 2011 09:25 PM
alabamamonte
Jan 28, 2010 12:01 PM
BeachBumMike
Mar 8, 2008 10:49 PM
