Throttle body issue
Old Aug 30, 2014 | 10:05 PM
itsame124's Avatar
Exclamation Throttle body issue
Hello, first off if i'm posting this to the wrong section i apologize this is my first post. Secondly I have owned 2 monte carlos a 1996 3.1 liter and my current one a 2006 3.5 liter flex fuel. and thirdly sorry for the long paragragh
now to my issue:
A month or so ago my engine light came on with the message "engine power is reduced". well i had it checked out, the code from the engine light suggested a bad throttle body. I then replaced the throttle body myself. (unplugged the throttle body sensor, unscrewed the four bolt holding it on, replaced with new throttle body, and reattached cord to new sensor that was attached to the new throttle body) i then re-learned the idle speed through chevys process on their help website. The engine light disappeared and everything was a okay for about a week and a half. then it started doing the same thing again. (engine light came on message appeared, obvious reduction in power from the throttle) It is continuing to get worse and sometimes it will shut off my engine display the message "starting disabled service throttle". I have been shuting the car off ( if it wasn't already off) and wiggling the wires leading to the sensor attached to the throttle body. i'd then close the hood and start the car and it would act normal (engine light still on) with no reduction in power until the next time (which was usually about 30 driving min later give or take) recently a new symptom popped up when i am going uphill or giving it the beans it'll display the usual engine pwer reduced message and sometimes shut off the car. not only that but if it gives me the message and shuts off if i dont wiggle the wires or something of that nature when i start it the whole car shutters while the rpms go up and down. so did i just get bad luck and buy a faulty throttle body ( i bought i t brand new from o'riellys or however you spell that) or is there something else wrong with it or did i do something wrong?
Old Apr 28, 2016 | 10:20 PM
La'veil Gibson's Avatar
Did you ever get your problem fixed??
SirMonte34
Jul 24, 2006 03:31 PM
01whitess
Apr 8, 2006 04:12 PM
big green dog
Jan 11, 2006 01:24 PM
montejass
Jun 3, 2005 11:53 PM
