Throtle response, need help...
Old Jan 11, 2012 | 07:38 PM
jester81's Avatar
Default Throtle response, need help...
I have a 87 SS and my pick up is sluggish. Is there any quick things I could do to try and improve the power? Any help would so help me out. Thanx for your time.
Old Jan 12, 2012 | 12:46 AM
Sliver's Avatar
Sluggish in your opinion or sluggish with something wrong? Has it had a tune-up? Any mods?
Old Jan 12, 2012 | 08:49 AM
jester81's Avatar
Well I know theres an exhaust leak, I did the plugs and wires. But its still real hesitant.
Old Jan 12, 2012 | 09:10 AM
Budsjlm's Avatar
doubble check that the rear butter flys on the carb are opening when you put the hammer down,
make sure your choke isn't sticking and probably wouldn't be a bad idea to check your timing
if it still has the car and you live in a state that doese not require it rip it out it could be plugged, mine was starting to melt apart when i took mine off along wuth 90% of the emmisions junk
Old Jan 12, 2012 | 12:22 PM
Jester_20's Avatar
good call
Old Jan 12, 2012 | 11:24 PM
Budsjlm's Avatar
Originally Posted by Jester_20
good call
Did partially have a good reason, cat was F'ed, smog pump Seized, pipes for the pump where leaking, ect,
Original poster let me know if you need any pointer on it, only thing it wouldnKt let me do was remove the egr tried blocking it but it wouldn't idle for shet, but that is the 305 won't have any of that with my 350
jaydflash
Aug 29, 2014 03:38 AM
EJFX
Jul 24, 2013 04:09 AM
RickCoMatic
Oct 22, 2009 09:26 AM
monte carlo 3831
May 4, 2009 10:53 AM
mickey
Aug 23, 2006 05:31 PM
