Are these just plug and ....
Old Jun 19, 2014 | 02:21 PM
joeykl66's Avatar
Default Are these just plug and ....
OR IS THERE OTHER WIRING THAT NEEDS TO BE DONE? TY GUYS
Old Jun 19, 2014 | 02:22 PM
joeykl66's Avatar
Old Jun 19, 2014 | 03:06 PM
TomF106SS's Avatar
That's the ones I got.
Yes, there is wiring that needs to be done.
The headlights works as normal, on the plug.
But, the halo's and the 4 little LED's at top need power.
The reason they are separate is so that you can power them how ever you chose. If you hook them in with the low beam, they will only work when your lows are on.
I wired mine into the same circuit as the fog lights, that way I can turn the halos on without the headlights. Didn't work well, since the headlights are the daytime running lights.
One other thing. You will want to replace the outside marker light with an amber bulb. The white buld with the reflector behind it looks bad.
Spend the 3 bux and get amber side markers before you put them in, or you will need to take them out to change them.
Good Luck!
Old Jun 19, 2014 | 03:20 PM
joeykl66's Avatar
Ty tom. Already have the amber bulbs! So ya like them overall?
Cowboy6622
Feb 6, 2012 10:56 AM
oh3monteSS
Apr 16, 2011 04:03 PM
Dade Chevy
Feb 19, 2009 06:43 AM
BeachBumMike
Aug 15, 2007 07:06 PM
