4th Gen ('81-'88): Temp sensor and temp switch
The sensor in the t stat housing feeds the ecm, the sensor that feeds the gauge, if you car is so equipped is in the head between #1 and #3 cylinder.
If your car has a light instead of the gauge, then no reason you couldn't move it to the head.
so since it has a gauge I can't move it to the head? What about the other one is that one for the fan?Thanks again
