4th Gen ('81-'88): Temp sensor and temp switch
Old Apr 22, 2017 | 03:26 PM
Griffinc's Avatar
Default Temp sensor and temp switch
the thermostat housing on the original 305sbc I'm rebuilding and was wondering if you can put the 2 sensors in the block or do I have to leave them In the original thermostat housing
Old Apr 26, 2017 | 05:58 PM
Aerocoupe86's Avatar
Monte Of The Month -- November 2016
The sensor in the t stat housing feeds the ecm, the sensor that feeds the gauge, if you car is so equipped is in the head between #1 and #3 cylinder.
If your car has a light instead of the gauge, then no reason you couldn't move it to the head.
Old Apr 26, 2017 | 06:41 PM
Griffinc's Avatar
Thank you, I checked it has a gage no light it's on an 84 ss Monte Carlo
Old Apr 26, 2017 | 06:46 PM
Griffinc's Avatar
so since it has a gauge I can't move it to the head? What about the other one is that one for the fan?Thanks again
