6th Gen ('00-'05): Temp guage not moving and fans constantly running
Old Nov 20, 2018 | 09:42 PM
bensond32's Avatar
Default Temp guage not moving and fans constantly running
On my '01 MC SS (3.8L), the cooling fans constantly run while the engine is running and a few minutes after the key is turned off. The temperature gauge is reading the lowest it can go. I have replaced the thermostat and the coolant temp sensor. The thermostat doesn't open and the car does have heat. I am very confused on what is wrong. Any help is appreciated.
Old Nov 21, 2018 | 06:52 AM
Smile
So are the fans roaring or just running?
to check the thermostat to see if it's working or not, start the thing up with the radiator cap off, when it warms up enough it will show circulation (old school way).
Also the system after the Thermostat replacement needs to be bled out. if there is a bubble in it, it can overheat.
It could be the intake manifold gaskets are bad and they need to be replaced. This will cause the overheating issue. Check out the list of youtube videos in this link.
https://www.google.com/search?source...60.Srw4pCWcHjs
Old Nov 21, 2018 | 07:55 AM
bensond32's Avatar
Last night after I installed the thermostat, I let it run for about 35 minutes with the bleeder valve open to bleed the system and the thermostat didn't open then. I could squeeze the upper radiator hose. The fans were running like the engine needed to be cooled down.
As of this morning; I let the car warm up as normal for about 20 minutes (it's like 20°F here in Minnesota) and then started going to school. On my way to school, the temp guage went up to the normal operating temperature and fluctuated between 200 and 190ish like normal. I couldn't tell if the fans were still roaring or not. I'll know more later today. I am going to bleed the system later on today as well.
John2689
Jun 12, 2016 08:15 PM
michelob
Jul 21, 2015 11:21 PM
Jayhawkbrown
Dec 18, 2013 11:14 PM
Arrestedone
Aug 17, 2013 10:39 PM
04IntimidatorSS
Aug 4, 2012 10:14 AM
