Switching to Mobil 1 Synthetic
Old Oct 20, 2006 | 10:20 AM
06MonteSS's Avatar
Default RE: Switching to Mobil 1 Synthetic
I use Mobil 1
Old Oct 30, 2006 | 08:22 AM
04 Intimidator's Avatar
Mobile 1 is just simply the best choice to go with in any car. It costs more, but it simply is the best.
Old Oct 30, 2006 | 10:31 PM
04MonteLS's Avatar
ORIGINAL: Bigg J
Excellent. So, for older cars, it was necessary to break them in first? This has been a very informative thread for me. I think I will certainly switch at the next oil change.
So...what's the concensus? Mobil 1 or Royal Purple?
Personal preference. I'd say get the one you can find for the best price. But definitely make sure you get a Mobil 1 oil filter!!!
Old Dec 9, 2006 | 01:54 PM
24_48Fan's Avatar
There is no evidence that supports that Mobil 1 or Synthetic Oil will make your engine last longer.
Old Dec 9, 2006 | 04:42 PM
07 Monte SS's Avatar
http://www.gtoforum.com/showthread.php?t=9029
A thread over at a GTO forum about synthetic oil. The GTO comes with Mobil 1 from the factory.
IMOA, a good choice.
Old Dec 9, 2006 | 05:08 PM
http://www.c66racing-synthetics.com/...etest11-05.htm
A synthetic oil testing.
Old Dec 9, 2006 | 05:38 PM
wiz kidd's Avatar
i use royal purple 5w30, i find that mobil one is too expensive, and i think that i get better running with the royal purple
Old Dec 9, 2006 | 06:35 PM
ORIGINAL: wiz kidd
Say Wiz, where do you get your RP & how much a Qt/case do you pay ? Thanks.
Old Dec 9, 2006 | 11:24 PM
24_48Fan's Avatar
Consumer Reports did a test on both Dino oil and Synthetics on NYC taxi cabs. They put special engines in that they had carefully tested cylinder diameters and the weight of the pistons with rings, plus some stat with the bearings, but I'm not sure what it was.
They then only put certain brands in certain engines. They had 12 cars for each brand. 3 cars would get changed at 3,000, 3 at 6,000, 3 at 9,000 and 3 at 12,000 miles. They had either just under or just over 100 engines for this test. They ran the cars for 150,000 miles. Then they took the engines apart and weighed and measured for wear. 1 engine failed, and it was an engine that was changed every 6,000 mile. Their findings were, there was no difference that they could measure between the 3,000 and 6,000 mile engines. Between the 6,000 and 9,000 mile engines there was a slight difference on the dino oil cars but no difference on the sythetic cars between 3, 6, and 9,000 in engine wear. Between 9 and 12 there was signifigant enough difference that they could measure it and definately not recomend a 12,000 oil change interval for both synthetic and Dino oil. All of the 12,000 mile cars were starting to consume oil in the 1 qt every 1,000 to 2,000 mile range.
There was absolutely no difference between brands and only minor difference between dino oil and synthetic.
I will stick to Castrol GTX and my 4/5 month 2,000 mile change interval. I don't buy into an Oil Monitor System that says ok for 25,000 miles.
Old Dec 10, 2006 | 02:05 AM
ORIGINAL: 24_48Fan
I looked for the Consumer Reports on the NYC taxi cabs testing on Synthetics Oils but couldn't locate it but I did find this one testing report on NYC taxi done by AMSOIL. I did read that Consumer Reports quoted "Don't spend extra money on synthetic oil unless your car calls for it". The newer GTO comes from the factory with Mobil 1 so whats good for the GTO beast IMOA is good for my 07 Monte SS.
http://www.performancemotoroil.com/Taxi_test.html
