Supercharger Maintenance
Old Sep 8, 2008 | 01:20 AM
Buddha4's Avatar
Default Supercharger Maintenance
Hi everyone. I have a 2005 Monte Carlo SS Supercharged
I am wondering about the maintenance on it. Like how do you replace the oil, add oil to it, and what type to use?
Old Sep 9, 2008 | 11:04 AM
sorcier11's Avatar
Default RE: Supercharger Maintenance
Hi Buddha.
I just replaced the oil in my '04 intimidator supercharger and it's not as hard as it might appear.
You'll need a set of allen keys that fit in the plug on the supercharger. You'll find the plug near on the s.c. tothe leftof the cover that is over the supercharger. It's black. I found it easy to remove the cover first but you don't have to. I'll assume you know how to do this.
Next, I found an old bottle of window cleaner and took the nozzle and plastic line from the bottle. I then put the line into the supercharger hole and started squirting the oil into a plastic container. Now, you might have heard that this oil stinks. It does a little but it won't make you sick. Mine was a shade of brown when it came out. Just aim the line inside the supercharger in all directions that you can for as long as you are sucking out oil. Do this until you aren't pulling any oil anymore.
To refill, get a funnel with a small neck that will fit inside the hole where the plug goes. I used a small rubber fuel line to help guide the oil. The supercharger oil can be bought at any chevy dealership. Here in Ontario, Canada, it cost me about $5 per bottle. Get two of them. You won't use both but you will need more than 1. Your mileage may vary.
The oil in the bottle will be clear (which led me to believe my old oil was getting a bit old). Just pour it in until it reaches the lip of the hole where the plug would be. Screw the plug back in, put the plastic cover back on and you're done.
Very easy.
Old Oct 10, 2008 | 06:40 PM
04 Intimidator's Avatar
I wouldn't worry about the discoloration too much. I read somewhere that it is just a change in the properties of the oil from the heat.
Old Feb 26, 2010 | 03:48 PM
montes my python's Avatar
pick up a suction gun at the local parts house they are cheap, makes the job fast, that stuff stinks when it comes out
Old Mar 10, 2011 | 06:47 AM
Dastankos's Avatar
About how many miles does it need to be changed? I got 55k on my '04 Dale Jr. and I wanna keep her runing real good.
Old Mar 10, 2011 | 07:19 AM
Old thread, but I would do it now, maybe every 50k?
Old Mar 10, 2011 | 07:40 AM
I'm changing mine every 30,000k miles. I changed it when I got it at 60k and I will change it again at 90k.
Old Mar 25, 2011 | 06:30 PM
70monte1's Avatar
My Dale Jr had about 90,000 miles on it before I changed it. I doubt the first owner ever had it changed. My oil was dark but not black.
Wayne
Old Oct 2, 2011 | 12:25 PM
bblackstone's Avatar
Default thanks
Love this site!!!!!!!!!!! Thanks for the directions on the change of oil on the supercharger.
Old Oct 2, 2011 | 11:28 PM
Mr.Monte's Avatar
i changed mine at 30k and im now at 63k im thinkin about having it done again. hmmm.
