Strange noise coimg from behind the passenger side dash
Old Nov 15, 2013 | 04:00 AM
BLACKSSMC's Avatar
Default Strange noise coimg from behind the passenger side dash
Hey guys when I pull off after start up I can turn left or right and I hear water circulating from behind the dash. can anyone help me out with this strange noise???
Old Nov 15, 2013 | 09:21 AM
03SSLE's Avatar
Chances are the drain for the evaporator is clogged and water is accumulating in the casing. Look near the center of the firewall (under hood) for a rubber drain hose. Pull it off and clean the nipple and passage out with pipe cleaners or compressed air.
Old Nov 15, 2013 | 05:17 PM
BLACKSSMC's Avatar
ok cool i wil try that, i have a 2002 ss will it still be in the same place??
Old Nov 19, 2013 | 08:07 PM
Johnboyp92's Avatar
Remove all the air pockets out of your cooling system probably an air bubble
joedaslik
Apr 1, 2018 10:37 PM
kanianic
Jan 1, 2011 07:03 PM
saigashooter
Mar 18, 2010 10:25 PM
harbringer314
19
May 8, 2009 04:16 AM
Endo
Mar 23, 2008 06:41 PM
