Steering Tapping?
Old Nov 28, 2006 | 08:59 PM
kutch720's Avatar
Default Steering Tapping?
Everytime I turn my car left or right I get this little tapping in the steering wheel. I don't believe that it is coming from the front end. Just wondering if anybody know's anything a bout the steering colum itself. Do I need a new bushing in there or it needs to be tightened? Any help would be great. Oh yeah it's on a 04 SS.
Old Nov 28, 2006 | 10:18 PM
pinhead's Avatar
Default RE: Steering Tapping?
Had a Cutlass that did the same thing. Took it to a dealer, they couldn't find anything wron and said it should be ok. Drove car for 10 years after, then sold it. No worse for wear. Yes, a little annoying though....just drive in straight lines?!
Old Nov 28, 2006 | 10:34 PM
2000LS's Avatar
comes from a binding in the intermidiate steering shaft, gm makes a lube kit for it
Old Nov 29, 2006 | 06:06 PM
kutch720's Avatar
Thanks for the info. Also is it very hard to put the lubricant in? Do I have to take the steering wheel off?
Old Nov 29, 2006 | 10:05 PM
InTheIROC's Avatar
It's pretty easy to lube the intermediate steering shaft yourself. Took me about 30 minutes. Here is someone's walkthrough you may find useful:
http://www.colinkraft.com/shaft.php
Good luck!
Old Dec 8, 2006 | 08:46 PM
jeffsmonte's Avatar
I have this with my 03 as well. Gets annoying.
Old Dec 9, 2006 | 06:17 PM
fastback4's Avatar
I had a steering box recall on mine. You might call a dealer and see if your's is defective
2001silverSS
May 2, 2012 03:47 AM
yankeesmike
Feb 15, 2011 10:15 AM
irulesoha
Aug 19, 2010 02:32 PM
irulesoha
Mar 1, 2010 11:00 PM
Xx-007-xX
13
Sep 9, 2009 09:36 PM
