Steering Column 87 Monte
Old Oct 13, 2005 | 05:08 PM
locs650's Avatar
Default Steering Column 87 Monte
Need help in fixing my steering column. Not sure how to get to the four bolts that hold it to the dash. Does anyone have any ideas?
Thanks
Locs
Old Oct 14, 2005 | 08:46 AM
mickey's Avatar
Default RE: Steering Column 87 Monte
most of the time on those cars , you just take the lower dash part off in front of the colum. there should be three screwes or four acrossed the bottom ov it and some clips on the top.
take them out the pannel fals down and then you can acsess those bolts .
Also good ideal to etheir replace or at least realy cheack the rag gear and the bottom of the steering shaft. It is the gear that you run bolts threw it.
Good luck and enjoy
erosem21
Apr 3, 2012 02:52 PM
echolmberg
Sep 5, 2008 02:57 PM
teddy620_2000
Oct 9, 2007 06:15 PM
krandall
Dec 16, 2006 07:24 AM
