Steering clunk
Old Nov 24, 2014 | 08:51 PM
avendo's Avatar
Default Steering clunk
I have a noise under the dash when I turn the wheel seems like the steering shaft maybe? I changed the one in my 03 Bonneville,do monte's have the same problem?
Old Nov 25, 2014 | 07:46 PM
GTHSS's Avatar
Yes. The intermediate steering shaft in the Monte can get dry and start making noise. You can have it replaced or have it "exercised". Basically that is where they take the shaft out, force grease in and work it until it works smooth again.
Old Nov 25, 2014 | 07:58 PM
ohara's Avatar
Here is a link to a write up from a fellow member about lubricating the steering shaft
https://montecarloforum.com/forum/fw...reasing-33173/
It's got pictures and step by step instructions which should help you
Old Nov 26, 2014 | 06:57 AM
avendo's Avatar
Will the shaft i took out of my 03 bonneville fit monte carlo?
Old Nov 26, 2014 | 07:14 AM
avendo's Avatar
I looked it up on rockauto.. Its different
Old Nov 26, 2014 | 04:48 PM
avendo's Avatar
problem with me is I cant fit under the dash like I used to be able to..out in eng bay is the easy part.
labnjab
Jul 1, 2009 08:51 PM
Endo
May 4, 2009 02:35 PM
White05LT
Feb 14, 2009 02:28 PM
Sciggy
Mar 5, 2008 08:08 AM
yzf125
Apr 30, 2006 11:21 AM
