Steeing wheel vibration
when I press the brakes I get a feeling thru steering wheel like a click. not a vibration like bad bad rotors. Any ideas?Thanks Steve
Hi Steve,
How many miles on your 01 S.S. ?
Check out the below links...I hope they help you! Good Luck
Anyone ever deal with the Intermediate steering shaft (clicking ...
<cite style="color: rgb(0, 153, 51); font-style: normal;">montecarloforum.com › ... › Your Ride › Tires & Rims & Suspension</cite>
7 posts - 6 authors - Oct 27, 2012
2001 Chevrolet Monte Carlo ... that GM has produced since around 2000-2007 had a MAJOR ISS (intermediate steering shaft) problem. In both ...
How To - Intermediate Steering Shaft Greasing - 1 post - Jan 5, 2012
List of Common Monte Carlo Problems and Solutions - 10 posts - Aug 9, 2011
labor time on intermediate steering shaft... - 9 posts - Jan 8, 2009
Steering intermediate shaft - Monte Carlo Forum - 10 posts - Oct 23, 2005
More results from montecarloforum.com »
Thanks for your reply I bought the car 3 weeks ago it is very clean but has 164k miles. It is hard to explain my issue it doesn't make noises when I turn but I feel something transmitting thru steering wheel when I push on brakes. Thanks Steve
Hi Steve,
Have you pulled the wheels & checked your brakes (4 wear) & also your rotor's for wear & scratch marks ?
Also, sometimes road debry or a small stone(rock) can get between the brake pad & rotor ?
I'm not a expert tech (4-Sure), so check back to see if one of our expert tech member's post on your problem...Good Luck from `Space
anarchy1974
Jan 7, 2011 06:25 AM
tweeder199601
Aug 22, 2010 06:53 PM
