6th Gen ('00-'05): starting/stalling issues
Old Mar 24, 2017 | 10:47 PM
zeuster3gm's Avatar
Default starting/stalling issues
2000 ls intermittent hard starting/stalling issues cranking, begins to start but doesn't. stalls at various speeds. sometimes will start right back up, other times not. sometimes starts and runs fine. have changed fuel pump, regulator, cam sensor, plugs. getting on my nerves. HELP PLEASE...
well for anyone interested i found the problem. car finaly would not run at all. problem was the ignition switch assembly. the backside where the wires plug in. i took it apart and found some burnt marks on some of the electrodes and such. i sanded them clean and car fired right up and is running perfect. i was elated after 3 months of brain boggling. hope this helps someone...
