Starting Problem 2007 3.5 V6
Old Nov 20, 2012 | 07:59 PM
LostSummer's Avatar
Default Starting Problem 2007 3.5 V6
I am new to the forum. I just bought a 2007 Monte LT with the 3.5 Liter V6. It has 150000 miles on it. When it runs, it runs great. I've had it for about 2 months and am having a starting problem. So far I have replaced the starter relay, the battery, and the battery cables since the battery cable was damaged by the previous owner. As of right now the car will not start.
When I turn the key, everything comes on. I go to start the car and the starter clicks one time and the lights dim. When this started happening, the door chime and the front speakers also quit working. I don't know if this is related.
I removed the starter from the car and bench tested it and it activated perfectly. I cleaned all the ground connections, and the starter. I reinstalled it and the same thing happened. I turned the key, all the lights came on, and the starter just clicked once. I've tried to jump start it in case it wasn't getting enough of a charge, but it didn't change anything. Is this a bad starter, or could it be something else? Also would anyone be able to verify which post on the starter the 2 cables attach? I want to make sure that they are installed correctly.
Any help would be greatly appreciated.
LostSummer
Old Nov 21, 2012 | 08:12 PM
Bob's Avatar
Bob
sounds like the car is getting no gas, you may have a fule pump that went bad. the pump sits inside the gas tank, if that is what wrong with it , your looking at about a $700 repair bill.
Old Nov 21, 2012 | 08:20 PM
If it was a fuel supply problem the car would crank over but not start. It still sounds like there is an electrical problem somewhere, maybe a dirty connection, but it seems like you've looked at most of that.
Old Nov 22, 2012 | 02:33 AM
LostSummer's Avatar
Default Update
Thanks for the ideas. Turns out it was the starter. One of my neighbors is a former GM Tech and he saw me out there working on the car. He came over and checked out the starter. Turns out the Bendix in the starter would work perfectly when out of the car but would not engage with the flywheel while installed. New starter and the car starts like a dream.
I'm still having the weird problem with the front speakers. Could it just be a bad ground on the radio?
Thanks,
LostSummer
Old Nov 29, 2012 | 04:02 PM
Bob's Avatar
Bob
Glad that you got your monte up and running, that was great that your neighbor help you out.
Old Nov 29, 2012 | 05:50 PM
Ricks 2006 SS's Avatar
Welcome to a great site. Glad you found out the problem with the starter. When you can post a few pic's of your car. And it wouldn't hurt if we knew your name also . Join us everyday on Off Topic and let us know what your up to. Enjoy
Hognutsdeluxe
Sep 29, 2013 08:57 AM
sws2000
Apr 24, 2009 11:27 PM
dub
Aug 13, 2007 07:50 AM
01whitess
Sep 20, 2006 10:33 AM
