4th Gen ('81-'88): starting issues
Old Dec 4, 2017 | 02:06 PM
junior1744's Avatar
Default starting issues
i have a 1987 monte carlo LS. The vehicle from my understanding has all its stock parts( as i have not done any work on it yet). As i was washing it the other day i had the bright idea of spraying up under the hood( not a lot of water but enough) to clear some of the webs and dirt. the car was running the whole time i washed the car and even after i sprayed under the hood. After i was done, i shut the car down without any problems. I came back about 25 mins later to start the car again, it would crank but not turn over. I assumed i gotten water possibly in the distributor which was the reason for it not starting, so i changed the distributor cap and the rotor button. after changing that the car turned over but ran at high idle. I shut the car off and tried to start it again, and now it wont start again! insugestions on what could be going on and how to fix this issue?
Old Dec 4, 2017 | 02:19 PM
Well, I dont know much about your engine but maybe something to check (until someone more knowledgeable comes around) is water in the intake?? Maybe??
I sucked up some water in a cold air intake going thru a really deep puddle once and there was like a week where the car just wasnt right and had the starting issue like youre talking about. -It would start, then it wouldnt, then it would, then not.... Plus the really high idle, which is what gives me the idea of water..
What I did (and I really dont know if its safe) was just let it be and hope I didnt kill the battery trying to start soo much..
Hopefully someone will be around soon.. Theyll know what to tell ya..
Old Dec 4, 2017 | 03:24 PM
junior1744's Avatar
thanks for the advice. i have not checked the intake yet. figured since it was running when i sprayed it, it wasn't a big issue.
Old Dec 5, 2017 | 10:09 AM
Yea, you know ive been told by 2 mechanics that cars from 1995+ its ok to spray under the hood if the car is running but that just cant be.. Furthermore with a car thats as old as '87.. Theres just too much stuff under there that can hold water, be water damaged, alternator are just a few things that come to mind atm...
I would think its unsafe to ever spray under the hood.. Youre supposed to bag off stuff and all that noise..
Good luck and I really hope someone else comes around and chimes in but if you do figure it out or need any other help, please post back..
