Starter spins but engine will not crank
As for the starter spinning, this could actually be a ground problem. Not sure if the '97 LS ignition compares with a '03 SS, but the transmissions are similar. In the case of the '03 S, I found the ground was bad where a large cable and two smaller, interconnected ground wires attached to a stud fastening the transmission to the engine. It's below the air intake duct on the driver's side. Make sure that's a clean ground.
Please keep us posted.
