7th Gen ('06-'07): starter
Old May 14, 2018 | 07:36 PM
monte07's Avatar
Default starter
ok have a Quick question my starter took a dump bunch of electrical smoke came from the location. what is the bolt size on the heads are they 13mm or are they a different size. I would like to take it off to see what the problem is. I checked all of the wires and every thing leading to the fuse relay box and checked the box as well. the engine spins I put a socket on the harmonic ballencer with the plugs out of it and spins freely. I admit I am a bad speller on some words and have horrible punctuation at times.
it is perplexes me on why the starter made that electrical smoke to be honest
Old May 14, 2018 | 08:26 PM
Jeffs02rwdSS's Avatar
Are the fuseable links on the power wire to the starter solenoid any good.On gen 6 cars they go to the alternator and the abs brake module. Imagine its same for gen 7 .
